跳转到主内容
加入维修社区 - 创建账户
由索尼公司于 2012 年设计并生产的数码相机。这是一款具备 Wi-Fi、GPS 和存储卡插槽的 1820 万像素相机。
Program Selection Wheel not working properly
Hi,
hope you can help: when I select a program it is often lost. For example: I set the wheel on P but on the screen the selection is - M. I have to move the wheel just a little bit to have the right program set again, but sometimes it's immediately lost again.
Maybe dust under the wheel? How can I clean it?
Thanks,
David
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Now the wheel works (even if ha become a little bit harder to roll), thanks!
Davide
由完成的
David, Glad to here it is working, pretty sure it will start easing up with usage after the cleaning. have a good day.
由完成的
添加一条评论
1个答案
已选择的解决方案
@catchtherainbow , David, Sony Cyber Shot, remove the battery, squirt a (little) 90% Isopropyl Alcohol under selection wheel and blow out/dry with canned compressed air. Repeat a couple time and this should clean out the dust/dirt from under wheel.
If this does not correct the issue button internal stops are probably worn and button assy. may need replace to correct. I will post a tear down guide if you wish to dig a little deeper into your device.
Sony Cyber-shot DSC-HX20V 外壳更换
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
David 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 59
总计 1,742
