跳转到主内容
This device is a personal paper shredder manufactured by Fellowes, Inc. in 2005. The shredder has the capability of shredding 7 sheets of paper at once as well as credit cards, identification cards, and cards likewise of the same thickness.
Why doesn't my shredder turn on?
When I try to use my shredder it won't turn on. I have it plugged in but it just doesn't want to work.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
1个答案
最有帮助的答案
Lack of power to the Fellowes T7CM device can be a result of different issues. Prior to proceeding, check to make sure that the power cord is properly inserted into the wall outlet. Also, check to make sure the device switch is properly placed in the "ON" position. If the device is properly plugged in and the switch is in its proper place, try powering on another device from the same outlet. Check to make sure the power cord is securely fastened to the device as well. For further troubleshooting information, refer to the troubleshooting guide.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Austin Roudebush 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 30
总计 7,562
