跳转到主内容
Released in August 2015, Model number: P01M, Intel Atom Processor Z3530
21 个问题 查看全部
Why won't the battery charge?
When I plug in my device the battery will not charge
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 7
3条评论
How can I tell if it is the port not working?
完成的
I'm refering to the usb Port on my tablet
完成的
I has been charge my zenpad but still don't want charge why?
完成的
添加一条评论
5个答案
已选择的解决方案
Hi Jessica! Have you tried testing a different outlet to ensure that the charger itself is not working rather than the device?
For more help try visiting our Troubleshooting Page! ASUS ZenPad S 8.0 Troubleshooting
这个答案有帮助吗?
得分 1
7条评论:
I tried that too but it didn't work
完成的
I have the same zenpad and found there is a trick to charging when the battery is completely drained. With the charging cable unplugged attempt to turn the zenpad on. The dead battery symbol will come on very briefly and when it does quickly plug in your charging cable. You will then see the green charging progress light.
完成的
Thanks, senor.stephen, it worked!!
完成的
Senor.stephen, thanks - worked for me too.
完成的
No, It did not work for me. Mine is still not charging nor would it be turned on.
完成的
显示更多的2条评论
添加一条评论
I think it is a problem with the port. If someone can create a guide on that it'd help a lot. The usb-c port in this device is quite weak as easy to break.
这个答案有帮助吗?
得分 0
添加一条评论
In my case I had to replace my battery as documented elsewhere in this section.
这个答案有帮助吗?
得分 0
添加一条评论
Turn on the dead tablet without using the power……the dead battery will flash on the screen. Before the dead battery icon disappear, plug the charger/cord to the power outlet. Wait maybe 10mins, then try turning it on while its still plugged in and it should turn on. It worked for me.
这个答案有帮助吗?
得分 0
添加一条评论
In our case my sons iPad 6gen 2yrs old will not charge and you have to do a hard rest then plug into charger and place the charging cable on an angle to get it connect..
I don’t know if it’s the port itself, or the actual software?
any help would be appreciated as it’s really only a new iPad
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jessica Voss 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 20
过去 30 天: 60
总计 20,028
