跳转到主内容
A titanium flat iron identified by model number HPK12 and manufactured by Hot Tools.
Why is my flat iron getting too hot?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
This could be happening for a number of reasons. First, I would make sure that the temperature control dial is actually changing the temperature of your straightener. If it isn't, I would recommend replacing it. If the temperature is changing, but it just seems hotter than it is supposed to be, I would contact the manufacture to see if they can offer specific specifications in order to test the plates to see if they fall within these specifications. You should visit our troubleshooting guide here for more information.
这个答案有帮助吗?
得分 0
1条评论:
"A number of reasons"? Well that's certain a nebulous answer.
完成的
添加一条评论
最有帮助的答案
@tkfrick , Check and see if iron is still under warranty and return as defective for refund,replacement or repair. If your curling iron is getting too hot and the temperature control select switch/thermostat is not controlling the heat setting as it was before, the switch is probably faulty.
Replacement parts are available through the manufacturer's website, beauty supply stores, or online some times. Link to contact hot tools below. Good luck.
http://www.hottools.com/contact-us/
这个答案有帮助吗?
得分 1
2条评论:
Student question.
完成的
Thanks mayer, I actually had the question answered and found this out, liked my answer better so I left it. Hope you had a good Halloween.
完成的
添加一条评论
添加你的答案
Tasha Frick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 48
总计 6,626
