跳转到主内容
加入维修社区 - 创建账户
The Microsoft Surface 2 was manufactured by Microsoft Corporation and is the second generation of Microsoft tablets. It was launched on October 22, 2013 and includes features such as upgraded processing power and screen resolution.
Change Battery Microsoft Surface 2
How do I replace the Microsoft Surface 2 battery?
What material should I use to assemble the screen with the back cover?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
I must disconnect the display from the rear panel with a heat gun, then to reassembly the Surface, I will have to use glue to assemble the tablet?
完成的
What should I use to connect the ribbon cable to the motherboard?
完成的
How do I remove the battery after removing the motherboard?
完成的
添加一条评论
1个答案
已选择的解决方案
@piero90, Piero, remove the old glue/tape with a (little) heat and a plastic scrapper/credit card/fingernail, then use some 90% isopropyl alcohol and a lint-free cloth to clean the remaining adhesive. Use a good quality thin 2 sided tape to put back together, which you can find doing a google search/hobby shop/small electronics repair store when you figure which width would work for you. Links below show tear down of the Surface 2 and adhesive strips being applied. Check the attached links,instruction and guides, Good luck.
http://www.techrepublic.com/pictures/cra...
https://www.youtube.com/watch?v=Man6w3sd...
这个答案有帮助吗?
得分 4
22条评论:
How I remove the ribbon cable in the Microsoft Surface 2?
完成的
@piero90 , Piero, at 27.00 min's in on video shows ribbon cable removal and the 2nd link here shows more detail of the cables removal, good luck with your device.
Microsoft Surface 2 Screen Replacement
完成的
Then I have change the battery, I must to use glue or thermal past to reassemble the tablet?
完成的
@piero90 , Piero, it would probably be best to reapply the thermal paste if removed and glue to a like factory install to prevent possible problems. Have a good day.
完成的
So I must to use the glue and the thermal paste together?
完成的
显示更多的17条评论
添加一条评论
添加你的答案
Piero Sabino 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 38
总计 4,724
