跳转到主内容
加入维修社区 - 创建账户
LG 冰箱 LFX25960** 的维修与信息指南。这是一款由 LG 电子生产的下冷冻室冰箱,配备抽屉和开门两种存取方式。本页面涵盖了型号匹配 LFX25960** 的相关信息。
Need to replace ice maker
I had the ice maker on my LG side by side refrigerator, LFX25960ST, changed last year under warranty. Same problem again, but warranty is expired. I'd like to do it myself. Is there a guide that will explain the steps to be followed in replacing the #AEQ3675901 ice maker?
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary. Water hardness has a lot to do with how long a ice maker will work. These things gum up quickly.
Here's the ice maker assembly: LG Ice Maker Assembly Kit - AEQ36756901
Here's the water filter: 5231JA2006F - LG Refrigerator Filter
Water inlet valve: LG Refrigerator Water Inlet Valve - MJX41178908
I would remove it and let it warm up and play with it to try to determine where the problem is.
产品
$53.99
Produces ice in specific LG and Kenmore refrigerator models by assembling a complete ice maker with housing and control device.图片
产品
$239.99
Controls the flow of water into the refrigerator for ice and water dispensing functions.图片
产品
$70.99
这个答案有帮助吗?
得分 2
1条评论:
research +
由完成的 分享
添加一条评论
Before you replace the ice maker check the plastic tabs that are covering the ice chambers where the ice cubes are frozen. In my ice maker one of the tabs was severely bent and interfered with the mechanism, resulting in a loud clicking and grinding noise. I bent the tab back and the ice maker has been working fine since.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jim 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 6,611
