跳转到主内容
加入维修社区 - 创建账户
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
Why does it do this?
I have a 2003 Nissan Altima, when I crank the car up and put it in drive it stars running bad or might go dead. So I crank it back up and put it in first and start off and put it straight to drive it runs fine, doesn't run hot or anything, but if I stop at a stop sign it'll start running bad again and have to repeat the same step, from first straight to drive, any idea what this might be?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
@hutch6 not sure where you are but I would get the OBD scanned to see if it throws any codes. Sounds like it is coming from the transmission.
Rep: 1
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Shane, This could be caused by a few things. It sounds like your transmission torque converter lock up/solenoid may be malfunctioning/sticking. Take into a good shop, have them scan for trouble codes, diagnose and estimate repair. Good luck.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Shane hutcherson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 144
