跳转到主内容
Released in April 2011, the D5100 replaces the D5000 as one of Nikon's popular consumer DSLR cameras. It features a replaceable Nikon F-mount lens.
53 个问题 查看全部
Get an error message "r17" on my view finder
Get an error message in my view finder "r17" . The camera will not calculate the light and speed correctly and I get over exposed picture. In outdoor mode it works perfect. In "m" mode i should define the speed and aperture by myself and get wrong sign on the scale of the camera. .need help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Revital, r17 is showing up not an error code, it is telling you how many images you can take before the buffer fills up in a burst of shots according to Nikon forums.
Check the attached link,instruction and guide, not your exact Model # but lots of info.on problem your experiencing, Good luck.
https://www.flickr.com/groups/756291@N24...
这个答案有帮助吗?
得分 1
添加一条评论
Revital Paran that is not an error message. since it starts with the letter"r" it refers to the internal buffer capacity. The "r" stands for "Remaining" and the number is so that you know how many shots you can have in the camera's memory buffer. In case you wanted to shoot, continuously, for example, you'd have room for 17 shots. In 14-bit mode you will see "r15" and "r17" in 12-bit mode if the buffer is empty.
Check the manual exposure control. Manual under and over-exposure can be changed this way in most of the modes.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Revital Paran 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 32
总计 4,988
