跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for Panasonic's Viera line of televisions.
Tv won't turn on beeping every minute
My tv Panasonic viera wont turn on and beeping with flash red light every 60 second
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
facebook what model is your TV? What have you checked and what have you tried to fix this?
完成的
添加一条评论
2个答案
已选择的解决方案
Panasonic TV Blink Codes for All Panasonic Models
Panasonic Plasma TVs have a built in circuit for fault diagnostics. If a fault occurs on one of the internal circuits, the firmware in the TV will detect it and output an error in the form of a blinking LED lite. The exact error is represented by the number of blinks in each series of blinks. By using this fault error code, you can diagnose the problem with the TV without even opening it. First, be sure you are counting the blinks correctly – it is very important to correctly diagnosing the problem. To do that, turn the TV OFF, and then back on and count the number of times the LED blinks. Repeat the process to confirm, and then look up the error code on the table below. This will very quickly diagnose the problem and tell you what board needs to be replaced or repaired.
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards (SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards (SC floating voltage area)
8 blinks Driver SOS 3 SS Board (SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board with IC8001 (Pesks Lite 2)
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
facebook, Try unplugging the set for an hour, then plugging it back in. Check the owner's manual for reset procedure. With no model # it is hard to say how to reset it. Give this a try, usually involves holding down the power button and menu or mute button when TV is off. Good luck.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
facebook 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 3,166
