跳转到主内容
微软第三代Xbox游戏机于2013年11月22日发布。
727 个问题 查看全部
My xbox one is not reading disc
when i came home one day from school i go up to my room so i turn on my tv and my xbox one so i sign in to my account by the way its abikdemt85 i know slow name so anyway i crack open my games case and my game is not in there so i press the eject button on my xbox and when i ejected it there were to games in there i was like wtf so then then i find out my little baby brother got in to my games and the bad thing is that he broke my disk drive so now that every time i insert and eject a disc it makes a clicking sound i idk why but its broke so if anybody could help that would be helpful before i open up my xbox and soultions
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
How long have you had the console? It could be worth sending it off for repair under warranty.
完成的
添加一条评论
2个答案
最有帮助的答案
It's quite likely that some of the internal pieces inside the disc drive have been broken or have become misaligned. To find out you'll have to disassemble the disc drive and remove it from the outer metal case. You may have to compare it to pics online to see if anything is broken. There is a metal arm inside that often becomes dislodged and can cause the problem you are describing. If you can post some pics of the inside of it I can help more. Unfortunately I don't have any pics of video of how to do this at the moment.
这个答案有帮助吗?
得分 3
添加一条评论
If you put a few game cases (or something similar in size ) under the front of your xbox. So the front is higher than the back. It may help your xbox read a disk.
It's A temporary fix that may help get you by without spending money, and I've seen this work multiple times.
这个答案有帮助吗?
得分 0
2条评论:
Ya it definitely sounds like there are some foreign objects inside the drive still, or something is broken. If you still have warranty, I would send it in to MS. If you don't (or you don't want to mess with MS), I have used these guys before to fix the problem.
完成的
@allergy_boy We do not recommend sites to repair devices unless specifically asked for other wise it can be mistaken for spam
完成的
添加一条评论
添加你的答案
ejaylacewell 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 4
总计 4,772
