跳转到主内容
iFixit 使用 cookie 来增强网站功能、分析流量和个性化广告。使用本网站即表示您同意我们的 cookie 使用和隐私政策
The Linksys EA6900 Smart Wi-Fi Dual Band Router is a four port wireless router with three antennas at the back of the device. The device also has two USB (3.0 and 2.0) ports for memory storage.
No Wi-Fi network to connect to.
I cannot connect to the Wi-Fi network and the Wi-Fi name is not showing up on the Wi-Fi network list on my laptop. How can I connect to network?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Reset the router using the red reset button in the back of the device. Wait for a power reset and search for the device on the wireless network list. If that does not work verify that your router is ON and the Linksys logo is solidly lit. If you are far from the router, you might try moving closer to see if your device is out of the wireless network range. Using a computer attached to the router via a network cable, open the router's web-based setup page by entering myrouter.local or 192.168.1.1 and make sure that Broadcast SSID is ON.
这个答案有帮助吗?
得分 1
添加一条评论
The question is wifi name is not only showing on your laptop or everywhere else. If it is not showing only on your laptop means there is some technical fault in your laptop network settings. What can you do just follow the steps given below to troubleshoot Linksys wifi router not working on your laptop:
  • Restart your laptop. Most of the issues are only fixed by rebooting the devices.
  • Turn off and on wifi on your laptop.
  • Forget the network and reconnect by searching it.
  • Make sure you have connected with the correct wifi name or the wifi name is now changed. After resetting the wifi router you have to reconnect with the same wifi name. It won't auto-connect.
  • Search Windows mobility center on your laptop and restart the wifi from there.
  • Go to services.msc from RUN and restart wireless network services.
  • Reset your wifi router and set it up again.
  • Check your laptop's wifi card. It might not be working. You have to replace it.
In case none of your devices are finding wifi names, it means you have a problem in your Linksys router. In this case, you have to follow the instructions given below:
  • Login to your router admin panel by typing 192.168.1.1 on your internet browser.
  • Type username and password and then login. YOu can find it below on the Linksys router.
  • Go to Wireless settings and check whether wifi is enabled or disabled. Here your wifi services should be enabled and publically open for searching.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Rick Hsu 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 30
总计 10,535
