跳转到主内容
加入维修社区 - 创建账户
Screen goes blank randomly while working.
while working on my Powerbook, the screen sometimes fades into a black screen. The computer still functions, but has no usable screen. Most times while pressing down gently on the right side of the palm rest, the screen will come back as long as i am pressing the right side. If i let go, the screen goes back to black. I also have had success sort of twisting and putting pressure on the left side whrere the screen hinge is. When it finally does come back on without the added pushing down, it seems to stay on for days at a time. Then it will go thru periods of going black. What may be the problem, and is there an easy fix for it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I would suspect the Display Data Cable. It attaches to the logic board in the upper left hand corner. To test this, hook it up to an external monitor. If it fades and the image on the monitor is good, that would confirm it. I would first check the logic board connection. These cables can also get worn with time and cause these symptoms. In this case it would need to be replaced. Look over this guide to get you to the cable connection. Ignore most of it, just the part about how to open and get to the cable. PowerBook G4 Aluminum 15" 1.67 GHz 显示屏组件更换
Here's the part: [关联产品丢失或禁用: IF154-103]
这个答案有帮助吗?
得分 2
1条评论:
good answer +
完成的
添加一条评论
添加你的答案
Brad Smith 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 1,961
