Why does my computer take such a long time to open?
My computer is starting to take too much time to open after i press the button sometimes it take 5 hours and somtime it never work i really need someone to help me .
sura, You may have an infection/virus/adware/spyware on your computer. You should update your virus/ spyware protection and run full system scan. If this does not work it may be a program,update software or app that was installed causing issue, in which case you could try system restore to an earlier date when computer was OK and one at a time add removed programs, etc to see which program effects computer badly and then uninstall it. The operating system may have become corrupt also, in which case you would want to back up system and re install windows.
You can also do a google search on your issue as there is a lot of info. out there. Good luck.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 117
1条评论
sura sama what model computer is it? What OS are you using? Does it take this long for the computer to start or for the OS to load?
由 oldturkey03 完成的
