跳转到主内容
电脑制造商联想所生产的台式机的维修和支持指南。
92 个问题 查看全部
Why does my computer take such a long time to open?
My computer is starting to take too much time to open after i press the button sometimes it take 5 hours and somtime it never work i really need someone to help me .
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
sura sama what model computer is it? What OS are you using? Does it take this long for the computer to start or for the OS to load?
完成的
添加一条评论
2个答案
已选择的解决方案
sura, You may have an infection/virus/adware/spyware on your computer. You should update your virus/ spyware protection and run full system scan. If this does not work it may be a program,update software or app that was installed causing issue, in which case you could try system restore to an earlier date when computer was OK and one at a time add removed programs, etc to see which program effects computer badly and then uninstall it. The operating system may have become corrupt also, in which case you would want to back up system and re install windows.
You can also do a google search on your issue as there is a lot of info. out there. Good luck.
这个答案有帮助吗?
得分 2
添加一条评论
You probably have too many apps on bootup.
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
sura sama 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 121
