跳转到主内容
加入维修社区 - 创建账户
关于第二代 Apple iPad Wi-Fi 版更新机型的维修指南、拆解和故障排除信息,有 16、32 或 64 GB 存储容量可选。于 2012 年 3 月发布。可通过型号 A1395 和 EMC 2560 识别。它采用了更小的处理器核心和更新的内部结构。维修时需要使用加热和小心撬开。
Looking for WiFi Antenna Part?
I note that iPad 2 Bluetooth/Wi-Fi Antenna says its not for the EMC 2560 model, but is there a suitable antenna available somewhere?
Replace the Bluetooth Wi-Fi antenna compatible with the A1395 EMC 2415, A1396, and A1397 model 2nd generation iPad tablet.图片
产品
$14.99
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
So what's the verdict, does this one work? The post labeled as the answer is indeed AN answer but hardly a solution and leaves the issue annoyingly unresolved and in an ambiguous way. I indeed have an iPad EMC 2560 that I'm about to replace the logic board in and was going to grab the cheap & especially fragile parts for the numerous reasons to do so and not that I won't be able to complete my repair without it but now I'm just curious what is so different or incompatible about the EMC 2560's and what's the solution or reccomendation if one should happen to require a replacement antenna for this model. Thanks in advance.
完成的
添加一条评论
2个答案
已选择的解决方案
I think this is it: http://www.powerbookmedic.com/Wireless-3...
这个答案有帮助吗?
得分 1
1条评论:
Sorry but that one says its the 3G antenna not the Wi-Fi one ?
完成的
添加一条评论
I've replaced hundreds of iPad 2 antennas and never worried about which model it was. The connection is the same on them all and the mounting is the same. There are no electronics to deal with, its all analog.
You should be good to go. I do remember seeing a couple iPad 2.5s with weird antennas. If you could post a pic of yours, I could tell you 100%
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Wayne Lavis 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 14
总计 487
