跳转到主内容
1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
20 个问题 查看全部
Won't boot unless I remove the battery.
Hey guys,
I've got a customers MacBook Air, 13" Mid 2012. It was brought to me with the symptoms of it won't boot.
I have successfully got the machine to boot, but only after I remove the battery and let it sit for a minute.
I've tried:
- Resetting SMC
- Upgrading SMC (it was outdated)
- Different MagSafe adapter
- Booting without the battery (it gets very slow when the battery is disconnected)
- Booting without the MagSafe (won't boot at all, but it will stay running after a successful boot)
This is reproducible, after shutting down the machine it won't boot without first removing the battery. It will restart properly however.
Anybody have any ideas?
Thanks,
Eric
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Yes, The battery is Bad.
这个答案有帮助吗?
得分 0
3条评论:
I've replaced the battery with no change in symptoms
完成的
Then your charging circuits are probably bad, send the battery back and get your money back if you haven't already did that. (If you can). Did you get an answer of what happened to it. Kinda sounds like water spillage.
完成的
Yeah, it definitely sounds like your MacBook is in need of motherboard repair. I would suggest taking it to a third-party, reputable component-level macbook motherboard shop.
完成的
添加一条评论
添加你的答案
admin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 108
