跳转到主内容
加入维修社区 - 创建账户
How to fix leak
How to repair leaking shower diverter inside shower/tub faucet
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
John, Easy fix, remove and replace the tub spout with new one equipped with diverter. Your old tub spout will be attached with one of 2 methods, set screw under base of spout, usually an allen/hex type screw which needs to be loosened or the other attachment is spout is threaded onto stub pipe, in this case you will have to turn spout counter clock wise to unscrew and remove.
If diverter is the type found between the shower taps(3rd handle), this diverter handle/knob is remove and the cartridge is removed and replaced. Take cartridge with you to plumbing supply to mach it up.
Check the attached links,instruction and guides, Good luck.
https://www.thisoldhouse.com/ask-toh/rep...
https://www.youtube.com/watch?v=Pbw1JCf8...
https://www.youtube.com/watch?v=do_ltqVS...
这个答案有帮助吗?
得分 3
添加一条评论
Hi John,
This video might be able to help you:
这个答案有帮助吗?
得分 0
添加一条评论
Hi there,
The information on this website might be able to help you:
http://homerepairgeek.com/bathtub-plumbi...
Good luck!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
JohnPullen 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 42
总计 1,100
