跳转到主内容
Repair guides and support for your Samsung TV.
Sound won't stay on
My TV sound keeps going down on its own too 0 and won't stay on any number
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
rde70, Make sure button on remote is not sticking, remove batteries. The volume control seems to be an issue with some of the Samsung TV's. After checking out some forums, I suggest you open TV and remove the wire from volume button control board to interface board. This should fix your problem according to forums I have read.
https://www.cnet.com/forums/discussions/...
这个答案有帮助吗?
得分 2
添加一条评论
rde70 let us know which model your TV ius. If you ruled out the remote by removing the batteries, you are most likely having issues with the IR board.
这个答案有帮助吗?
得分 1
添加一条评论
You should give more information.
Try diagnosing the most obvious part. Set the volume up and make sure that the remote controller does not transmit signal to the TV. If you can, unplug the battery or make sure that no IR points to the TV (you can make sure it's not receiving a signal by pressing another button). If the sound goes down anyway, the remote is not to blame.
这个答案有帮助吗?
得分 0
添加一条评论
This is a software glich, unplug tv plug back in will solve this issue every time it goes out.
Software update is not available. Frustrating…
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
rde70 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 5,917
