跳转到主内容
This category includes all series of the Bose SoundDock speaker, manufactured from 2004 to 2009. Compatible with Apple products.
Resolve Bose SoundDock white noise issue?
Hi! I recently got a Bose SoundDock 1 for really cheap and it happens to have a problem that I have no idea how to resolve. When music is playing at low levels from my iPod, white sound is clearly audible. Sometimes, the problems is resoved by plugging the power cable in and out. How would I fix this?
Side note: Im using a newer iPod that firewire doesnt support (sound works but iPod doesnt charge).
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Simulr possible event I had, a lose power cord. the sound worked but when I pushed the power cord into the device until it was in secure the sound improved. I was pretty surprised. I was able to reproduce the odd lose cable problem.
plastic junk
I have other multiple problems one is a buzz I here intermittently that is reduce with a grounding wire...
完成的
添加一条评论
2个答案
最有帮助的答案
Try this guys: http://www.invebo.com/
这个答案有帮助吗?
得分 1
3条评论:
Thanks, though that's a bit late. In true Ifixit fashion, I opened up the speaker myself and fixed a ribon cable. That did the trick.
完成的
Do you have a link to details of the ribbon cable fix Imad?
完成的
Sadly I don't have a link. However, all I did was open the 2 'ports' at the bottom. Once I opened the big one, I saw a ribbon cable. I simply 'pushed into into place a bit more. I then opened the smaler 'port', lifted up the dock connector and blew some compressed air onto the whole assembly. I pushed in the ribboncable as much as I could and closed eveyrthing up.
So far its working and the speaker has no problems at all.
完成的
添加一条评论
2024 and I’ve just pushed the ribbon back in tight..sorted!!..:))
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Imad Knight 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 26
总计 3,245
