跳转到主内容
Black and silver single cup coffee maker with water reservoir on the left hand side. K40/K45.
keurig does not brew when pod is in
our keurig only drips coffee when the pod is in, we take it out & run it & the water comes out just fine. Why isn't it working with the coffee pod in it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Bernie Wagnild start off by cleaning the upper and lower puncture needles and the openings next to those. If after that you still have the same issue it could be an issue with scale buildup and the Keurig not having another water pressure to force it through the K-cups. Check this guide to see if you can get it cleaned.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Bernie Wagnild 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 186
