跳转到主内容
The JBL Charge 2+ made by JBL is the second generation of the JBL Charge brand.
Power button stays on
Was playing the speaker. It stopped on its own. The power button stays on wont turn off. No other buttons work. Less than a year old. Help please
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论:
Did you solved it ? Hoy?
完成的
I have the same problem. I just drain the battery till it automatically shuts off. Hope I can just fix the power button somehow...
完成的
添加一条评论
1个答案
Hello Rhona
Try the following steps (reset the CHARGE 2+):
1.In power ON mode press and hold the "Volume +" and "Phone" buttons at the same time for more than 3 seconds until it shuts off by itself.
2.Unpair/Forget the CHARGE 2+ from your device.
3.Turn the mobile device completely OFF.
4.Switch the mobile device back ON.
5.Turn the mobile device completely OFF "AGAIN". (this is important)
6.Switch the mobile device back ON.
7.Pair the CHARGE 2+ with your mobile device.
If the problem persists, check that the power button is not blocked.
Succes;
Homer 82
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rhonda 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 31
总计 1,002
