lvrbrndy does the TV actually turn on or is it just the pwer light that turns on? what have you checked? Unplugged the set for a while and then tried again? Have you taken the back off to check for any bad components on the boards?
lvrbrndy until you can check the commented things out, you might want to consider checking the no power flow chart. Your issue appears to be related to the power failure circuit. You will need a multimeter to check those components.
1条评论
由 oldturkey03 完成的
