跳转到主内容
加入维修社区 - 创建账户
Kenmore 微波炉的维修与拆解指南。
Why are some buttons not working
Some of my buttons are not working - like the numeric 5 button, the exhaust fan, and the STOP/Clear button
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
Hi,
I have sanyo Microwave Oven em-p540w,
yesterday touchpad wasn't responding, so i unplug 15 minute per your suggestion,
and plug back up, works like charm...
and 2 hours later again touchpad wasn't responding, so unplug and replug...
it's work again only for a while and take a nap...
Is this ready to trash?
由完成的
My micowave start button not working model sonakshi send me how to repair it
由完成的
Why is my microwave #2 button say #3 when I press as wrong number? Also when I press auto reheat button it automatically go to potato mode instead of castrolle. Since #2 button said #3, I cannot set time as pm anymore. Just started this issues a month ago. I unplugged and plugged it back on and still have issues. Any suggestions? Please.
由完成的
添加一条评论
3个答案
已选择的解决方案
Unplug it for 15 minutes to allow it to reset. If the problem persists please give us your model number and I'll look at it further.
这个答案有帮助吗?
得分 4
6条评论:
I have tried that, but it did not work. The Model Number is 401.80084700
由完成的
Cause 1
Touchpad and Control Panel
To determine if the touchpad and control panel are defective, try pressing each of the buttons on the control panel. If some of the buttons respond correctly while others don’t, replace the touchpad and control panel.
Cause 2
Touchpad
To determine if the touchpad is defective, try pressing each of the buttons on the control panel. If some of the buttons respond correctly while others don’t, replace the touchpad.
Cause 3
User Control and Display Board
To determine if the control and display board is defective, try pressing each of the buttons on the control panel. If none of the buttons are responding correctly, replace the user control and display board.
Here's how to remove the panel, finding the part may be harder:
https://www.youtube.com/watch?v=YsBQYHdy...
由完成的
i have a gc but it works except the number buttons
由完成的
Pearlita, see the 3 causes right above your question.
由完成的
Samsung mw73ad-b/xtl . Only clock button and its minute & hour button respond. The minutes and hour button serve the dual purpose of setting time for 1 minute or 10 minutes. They do not respond except while setting time. Rest of the buttons are not responding
由完成的
显示更多的1条评论
添加一条评论
I’ve replaced my control panel and touch pad and still have buttons that don’t respond the main one being the start button. Is there anything else that can control this?
这个答案有帮助吗?
得分 0
添加一条评论
It may not be necessary to replace the touchpad and the control panel. You can take a blow dryer move it back-and-forth over the pads that don’t work, and keep pressing the pad up and down. they may come unstuck. This has worked for mine on several occasions. What happens is when you’re cooking the grease Will cause them to stick over time. Give it a try before you throw everything away.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alex Pechenik 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 21
过去 30 天: 82
总计 50,347
