跳转到主内容
加入维修社区 - 创建账户
Samsung NX30 是一款可更换镜头的无反相机。它支持高清视频录制,于 2014 年 2 月 18 日发布。
Lens will not focus
Hi!
I got this camera three months ago and very satisfied with picture quality. Recently, I noticed that 55 mm lens that came with the camera stopped focusing. It will focus only on 45 mm, but not on 18mm. I tried changing settings from manual focus and back. Took the lens off and put it back.
Thanks,
Maria
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Maria, I have had a similar problem (with a different camera/lens). I have noted two possible causes. First is in low light or low contrast. It seems that especially with low contrast, it depends on having a focal length that includes enough variation in contrast in the auto focus region. Two ways to potentially handle this. Once you have found a focal length you can focus at, hold the shutter down 1/2 way down, then change the focal length of the lens. OR - change the AF focus method to, say, center weighting.
The other thing I have noticed is sometimes the battery indicator say everything is okay, but it is not sufficient for focusing under these low light/contrast conditions. Changing/recharging the battery has often resolved the problem.
Hope it helps.
Mike
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mashahunter 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 40
总计 621
