跳转到主内容
The Samsung NX30 is a mirror-less camera with an interchangeable lens. It has HD video and it was released on February 18, 2014.
13 个问题 查看全部
Lens will not focus
Hi!
I got this camera three months ago and very satisfied with picture quality. Recently, I noticed that 55 mm lens that came with the camera stopped focusing. It will focus only on 45 mm, but not on 18mm. I tried changing settings from manual focus and back. Took the lens off and put it back.
Thanks,
Maria
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Maria, I have had a similar problem (with a different camera/lens). I have noted two possible causes. First is in low light or low contrast. It seems that especially with low contrast, it depends on having a focal length that includes enough variation in contrast in the auto focus region. Two ways to potentially handle this. Once you have found a focal length you can focus at, hold the shutter down 1/2 way down, then change the focal length of the lens. OR - change the AF focus method to, say, center weighting.
The other thing I have noticed is sometimes the battery indicator say everything is okay, but it is not sufficient for focusing under these low light/contrast conditions. Changing/recharging the battery has often resolved the problem.
Hope it helps.
Mike
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mashahunter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 171
