跳转到主内容
加入维修社区 - 创建账户
LG G4 于 2015 年 6 月初在美国发布,它一如既往地专注于高端规格和精致的时尚感,使其在高端智能手机市场中脱颖而出。根据运营商销售或无锁版(美国或国际版),该手机的每个版本都有不同的型号。众所周知,部分 LG G4 存在无限重启问题。
How do I replace the glass only?
How do I replace the cracked glass ONLY on my LG G4 without replacing the LCD display
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
7个答案
已选择的解决方案
If you have some skills you can do that, here is a little help:
LG G4 仅更换玻璃屏幕维修
这个答案有帮助吗?
得分 4
添加一条评论
https://www.youtube.com/watch?v=erkn7K6t...
这个答案有帮助吗?
得分 3
添加一条评论
I really would not recommend this route. The extra equipment you have to buy, the time it takes to separate the broken glass from the lcd, the risk of damaging the LCD while separating it, and the time it takes to remove the old glue from the lcd is not worth it. After that you also have to worry about permanent bubbles of the new glue between the new glass and the lcd.
这个答案有帮助吗?
得分 3
添加一条评论
You can replace the screen on a LG Stylo 4; I replace mine all the time. HOWEVER, unfortunately you can not replace the GLASS ONLY. You must replace the front end (or face) of the phone. You DO NOT need to buy a KIT. You only need to purchase the Front-End of the phone for replacement. Whichever color you want.
这个答案有帮助吗?
得分 1
添加一条评论
How do i fix my cracked screen
这个答案有帮助吗?
得分 1
添加一条评论
Presumably similar to these LG G3/G2 glass only replacement video, as LG G4 lcd construction is very similar to G3 and G2.
https://www.youtube.com/watch?v=H0dxMv5-...
https://www.youtube.com/watch?v=QrxIWVaM...
这个答案有帮助吗?
得分 0
添加一条评论
How how much does it cost to replace a front end on LG phone and will it work or could it possibly have problems would it be better to buy a new phone which is expensive or spend whatever your prices for replacing the glass mine is very cracked up please respond thank you
这个答案有帮助吗?
得分 0
1条评论:
Just sent you a message I'm asking you to send it to my email rather than post it on Facebook cvj 602@gmail.com thank you I want the answer sent to the question I just posted to you
由完成的
添加一条评论
添加你的答案
James Dodson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 12,435
