跳转到主内容
Device repair and troubleshooting for the 7" RCA tablet released in 2014, identified by model number RCT6773W22.
Green Border around Screen
My RCA tablet has a green dash border around the edge of my screen. I have tried turning it off and a reset but still the border and the device will not work. When touched the border will move to a box or rectangle around the area touched. Pls help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
4条评论
can you post pictures of what exactly is happening? this is a strange issue, never heard of it before. If you are getting a red border, resetting the settings in developer options will fix that.
完成的
My son has this issue . What soes it mean??? Help
完成的
post pictures of the issue
完成的
How do i get rid of that green border around my fire tablet i can't get in to anything
完成的
添加一条评论
3个答案
最有帮助的答案
I had this problem too, you have to hold the icon that you need to use until the green box pops up, and then double tap, once you have it unlocked, do the same thing (hold down and double tap) to settings, and turn off talk back (you might need to search it once your in settings, like I did) and then your tablet should be fine after that.
这个答案有帮助吗?
得分 3
1条评论:
I am having trouble now I am stuck in my camera
完成的
添加一条评论
How do i get this green box from my RCA tablet
这个答案有帮助吗?
得分 0
添加一条评论
I would check if you accidentally turned on show screen changes in a developer mode. if not it could be a small internal crack in the lcd. UPDATE: re reading it you have an assistive touch on. look in your settings and accessibility settings and make sure everything is turned off
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Liam Boland 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 4,564
