Loading slowly, not working.
My pc is loading slowly when I opening my drives.
Upgrade the hard drive to a SSD and upgrade the RAM (if your system allows). Just about any reputable SSD should work (Samsung, Crucial, Kingston, etc...) If you aren't sure, download the CrucialScan from Crucial.com
1) Copy the old hard drive to the SSD by attaching the USB to Sata cable and the cloning software.
2) Find the pdf instructions for the HP 430. Go to pages 48-50 for how to uninstall the old hard drive. To reconnect the SSD, just follow the instructions in reverse order.
Should solve the problem.
You need a USB to Sata III cable, 2.5 SSD and I would also get a kit to open laptop computers. Everything should run around $100 depending on your space needs. The more disk space you need, the more the SSD will cost you. There are lots of videos on how to upgrade your hard drive and RAM on YouTube
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 14
总计 253
1条评论
mrinalkanti1995 befiore any upgrades you want to tel us a bit more. What OS are you using? Did it just start to be slow? What capacity is your drive and how much of this are you using? Is it only slow when you open the drives? Does it boot slow? Have you done a virus/malware check? What have you checked?
由 oldturkey03 完成的 分享
