跳转到主内容
加入维修社区 - 创建账户
这是一款小型媒体流媒体播放设备,可直接插入电视的 HDMI 接口。由 Amazon 于 2014 年 11 月首次发布。最新版本配有语音控制遥控器。
Stick remote not clickable
The remote won't let me enter my pin and then if I click the select button it tells me my remote is not clickable - any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
I am having the same issue. I guess I sat on the remote and a combination of buttons was pressed activating the voice commands (this is not a voice command remote!!).
由完成的 分享
Thanks George that helped me my son dropped his remote in the tank and I had to take the batteries out put the remote in some rice over night then shake out the rest of the water out put it back in the box of rice for two hours. Then once I put new batteries in the voice control thing came on and it kept staying device not clickable until I held down all the buttons at one time. Then saw the green box's on the TV was gone and it started to work. Thanks so much
由完成的 分享
添加一条评论
6个答案
最有帮助的答案
So... I just found out that holding the left, right , and menu buttons simultaneously for 5 seconds will reset the remote. Good luck!!
这个答案有帮助吗?
得分 4
2条评论:
Holding The menu button alone fixed my problem
由完成的 分享
Thank you so much cuz my son did something to mine and it was going crazy and I was just flipping out this. Good used it in that work thank you
由完成的 分享
添加一条评论
Hold the menu button down on the remote. It will switch back to standard remote.
这个答案有帮助吗?
得分 3
1条评论:
This is the only thing that worked thank you so much my remote now works and isn’t saying control not clickable
由完成的 分享
添加一条评论
Holding the menu button fixed my problem!
这个答案有帮助吗?
得分 1
添加一条评论
What does it mean when it says remote not clickable
这个答案有帮助吗?
得分 1
1条评论:
由完成的 分享
添加一条评论
Worked!!! Thank You!
这个答案有帮助吗?
得分 1
1条评论:
I need help because it is not working my firestick remote
由完成的 分享
添加一条评论
I need help because my firestick remote is not working I have tried everything that it does what do I do?!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alex Battiste 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 14
总计 14,533
