跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1233 个问题 查看全部
wont charge dead battery
hi, i have a 5c that wont charge a dead battery but will charge a battery that has power?
i have change the charging chip (u2) and the power management chip but the problem remains. does anyone know what else coukd be the issue?
thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
@corklad I think what you are running up against is a battery issue. Amazingly enough we forget that the batteries in our "smart devices" i.e. cellphones etc are also smart batteries. They do more than just provide the needed power. If those batteries are discharged beyond a certain point ( that point on cellphone batteries is around 2.6V) your regular charging circuit does not recognize the battery. The battery then turns into something like a possum and plays dead. Sometimes, and I do not say it is smart or works all the time, you can wake those batteries up. Use a 9V battery and connect that to the positive and negative connection of the cellphone battery for a few minutes. This will "charge "{ the cellphone battery just above that point of not being recognized. Hope this makes sense.
这个答案有帮助吗?
得分 4
5条评论:
That's a pretty smart idea. I use something called a 'Apple Battery Fast Charging Activation Test Fixture' basically a charging board that allows you to revive dead batteries that are well under the required voltage in order for it to work properly.
Also useful for charging iPhone 4 and higher batteries too.
完成的
@benjamen50 you are using some pretty snazzy tools :-) I am just an old dude in bip overalls and got to use the old fashioned homemade tools ;-)
完成的
i changed the u7 chip and this has now solved the problem. i have no idea why it solved.
完成的
U7? Interesting . That is the Power Management Voltage Regulator IC. Great that you got it fixed.
完成的
Because the charging circuit probably uses a switching mechanism depending on the battery voltage.
I think that when the power goes in from the charging cable to the charging port then to the logic board think of it as two lanes where U7 is the left and U2 is the right.
Before it reaches the two lanes there is a voltage sensor chip that pings the battery to check what battery voltage it is at.
When the battery voltage is too low it routes the circuit to the left lane. But since the IC is damaged on the left lane it is just stuck there doing nothing.
But if the battery voltage is sufficient enough it uses the right lane and charges the battery as the IC on the right lane is functioning properly and allows the circuit to be complete.
This is just my assumption. So take it with a grain of salt.
完成的
添加一条评论
Hi friend,I think you need change the battery.
这个答案有帮助吗?
得分 2
添加一条评论
If it charges battery A but not battery B. Then I think it should be obvious that battery B is at fault.
这个答案有帮助吗?
得分 2
添加一条评论
Yes, a dead unchargable battery .
这个答案有帮助吗?
得分 1
5条评论:
an absolutely stupid answer.
完成的
@corklad - Well trevor. thats why I'm a professional and you're not. Click on my icon.
And you down voted me for trying to help you?
完成的
you didnt try to help. you just provided a stupid answer in the hope of getting a bit of credit. if you are a professional and this is genuinly the best addvice you could offer then best to find something new to be a professional at. i am a novice but have now solved this issue. i changed u7 and the phone is charging dead batteries again.
,please troll other post and stay off mine. your professional help is not required as the helpfull info is comming from other non professionals
完成的
Everybody else told you the same thing. I was just the first to answer and I certainly don't need the credit.
完成的
please go stroke your ego somewhere else. MR PROFESSIONAL
Leave the serious problem solving to us newbs.
完成的
添加一条评论
添加你的答案
trevor 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 162
