跳转到主内容
Faulty trackpad or swollen battery in Airbook mid-2012?
The trackpad no longer works in my mid-2012 Airbook. I opened it up and the battery doesn't appear to be swollen. How much swelling does it take to impede Trackpad action? Is it generally visible when it occurs?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
To test it remove the battery, here how:
2012年中 MacBook Air 11" 电池更换
Then boot with the Mag-Safe adapter plugged in. Try the trackpad.
Also there were EFI trackpad updates. They usually get installed when you update your operating system.
这个答案有帮助吗?
得分 2
2条评论:
Great suggestion. I did this and the trackpad still didn't work (meaning, it won't click at all). If you hold the keyboard upside down then there is play or movement in the trackpad, but once you turn it right side up it won't move at all. I wonder if there is some sort of tension or spring-like mechanism in the trackpad that has been damaged (meaning that it remains in the depressed position and doesn't pop up to allow for a downward clicking motion). I'll probably try a new trackpad and see if that helps. Thanks again....
完成的
I have not adjusted this particular trackpad and am not sure it can be, I found nothing on the web on doing it. Some things to try:
First hold the machine upside down with it booted up and see if it will work.
Next (to eliminate a possible software issue see if an external USB mouse will work on it.
Update your software to 10,11,5
Lastly, replace the pad. I would go with from iFixit as it carries a lifetime warranty. Here;s how to do it.
MacBook Air 11" Mid 2012 Trackpad Replacement
Here's the part: MacBook Air 11" (Mid 2011-Mid 2012) Trackpad
完成的
添加一条评论
添加你的答案
Grant Kester 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 1,092
