简介
请按本指南更换2012年中 MacBook Air 11" 电池。
注意: 如果有更换电池上有塑料薄膜, 不要去除它。这是用来保护电池的。
你所需要的
从靠近主板的边缘提起电池,并将其从顶壳中取出。
将其充电至100%,并继续充电至少2小时。拔下电源并正常使用以排空电池。当您看到低电量警告时,请保存您的工作,并保持笔记本电脑一直打开,直到它因电池电量不足而进入睡眠状态。等待至少5个小时,然后不间断地将笔记本电脑充电至100%。
在你安装好你的新电池之后,如果你注意到任何不寻常的举动或是问题,你可能需要重置你MacBook Pro的SMC。
请按逆序重组你的设备。
139等其他人完成本指南。
由衷感谢以下译者:
100%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
21指南评论
I followed the directions in the reverse order, but now I have the old battery in my laptop again. Help?
I love you Jenny. That is all.
Great guide. Identified my parts, ordered them per the suggestions, and had the battery swapped out in 10 minutes. I like to use a magnetic sheet to hold and organize my screws for repairs like this - it keeps the proper size screws in the proper holes. If you don't have access to magnetic sheeting like I do from my graphics shop, an oval car magnet or a fridge magnet will work as well. The screwdriver recommended are of better quality than I expected. Thanks Ifixit.
Incredibly easy - done in 15 minutes.
