跳转到主内容
加入维修社区 - 创建账户
使用阴极射线管技术。在很长一段时间内,老式显示器和电视都采用这种显示类型。维修过程非常危险,但对于较小的故障,维修是可能的。
Black lines on screen
There are black lines on the top and bottom of the screen. There are not any potentiometers on the back so I can't change thr picture manually. What can I do to make it look like 4:3 again. This is a crt tv by the way. Thank you in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
eraywhite what make and model is this TV? What have you tried? Post some images of what you see with your question. For that, use this guide 在已经存在的问题里加入图片 It will allow us to see what you see.
完成的
添加一条评论
1个答案
You don't specify what make or model. On the older crts the gross adjustments are inside the monitor the outside controls are for fine tuning.
DANGER! DANGER!
To adjust the gross setting it involves removing the back cover and working near the high voltage flyback with the power on.
ONLY USE PLASTIC OR INSULATED TOOLS
(I ALSO WEAR RUBBER GLOVES)
CRTs can KILL....
There should be three plastic potentiometers with slots cut into them for a small flatblade.
On really old CRTs they also used small magnets attached to the sides of the picture tube as well.
Adjust the monitor slowly. If possible have someone else watch the picture while you adjust so you can insure not touching a live board.
You life is not worth an inch of black screen.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
eraywhite 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 27
总计 1,405
