I cant make calls
It won't let me make phone calls it hangs up tight away
Had the same problem. Try turning off assisted dialing in call settings.
Hope this helped.
这个答案有帮助吗?
Changed setting "Voice over LTE preferred " to off.
Fixed my ZTE Z799VL
To get to call settings (in android 6.0.1) select phone, dialer, and click on the 3 vertical dots on the left side of the text field of numbers.
I don't understand
Same ph though
I put mine back to factory settings and haven't had a problem since. I wrote down my contacts first.
这个答案有帮助吗?
I'm not able to receive calls or call out from my zte phone
这个答案有帮助吗?
No able to make calls or receive calls from my zte
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 13
总计 17,473
14条评论
We need more information. Have you tried turn it off and again (not "sleep/suspend mode," but really powering down)? Have you changed anything recently? Does this happen with all local numbers? Finally, have you tried a factory reset to default state and tried again?
由 David Spalding 完成的
I have this problem as well, and I have done everything including a factory reset and still I have this issue. Perhaps a software flaw or something?
由 jasonglasgow123 完成的
Same problem makes no sound when dialing and then lists at bottom can not complete because of unspecified error. Many incomming calls go direct to voice mail when the signal is very good. Sometimes can not get to retrieve voicemail. It seams to have no pattern as to when it will not work. I have not been able to call any number for the past day (error caon not complete). 05/17/2017 by sehappraiser@gmail.com
由 Sid Holderly 完成的
I wonder whats wrong ive done nothing else could make calls eariler
由 Sandy Seamon 完成的
I couldn't call out, I had tried everything. After 2 30 minute phone calls to Tracfone and doing everything they suggested, still would not call out. When I saw the comment above about putting the phone back to factory setting I tried that and now my phone calls out. I was ready to buy a new phone.
由 termite2265@yahoo.com 完成的
显示更多的9条评论
