跳转到主内容
加入维修社区 - 创建账户
2.26 或 2.4 GHz / 白色塑料一体成型机身
Processor upgrade MacBook 2010
I have a MacBook Mid 2010, Processor 2.4 GHz Intel Core 2 Duo, and two 1GB slots, each of which accepts a 1067 MHz DDR3 memory module. I know i can get more RAM but, Is it possible to upgrade my processor?
Update (11/13/2018)
Is it possible to adapt a MacBook Pro mid 2012 logic board (and other parts maybe) in this system?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Thank you for this answer !
Making a comparison between the mb 2010 A1342 and mb pro 2012 A1278 logicboards, it seems to be just lightly different.
MacBook Pro 13" Unibody 2012末主板更换
MacBook 一体成型机身机型 A1342 逻辑板更换
Don't you think an adaptation is possible ?
由完成的
Sorry guy a very different logic board! Review the ports the MacBook Pro has a few more and the size and alignment is not the same.
由完成的
添加一条评论
3个答案
已选择的解决方案
Sadly Apple's laptops don't have removable chips (thin laptops tend not to). Here's a view of the logic board from the backside: MacBook Logic Bd. The larger chip with the grey thermal paste is the CPU, the other is the GeForce 320M GPU.
As you already have the premium model (2.4 GHz) there is no logic board swap out possibility within the models series. Likewise there is no newer logic board possible either as Apple completely redesigned the MacBook in 2015. So upgrading the CPU is not possible,
But! You do have some areas which you can gain performance!
To start with, I would bump the RAM up to 10 GB or 12 GB.
The next area would be the storage. Here you could swap out the HD with something bigger, I would go with a SSHD from Seagate as the best option here as your systems SATA port is only SATA II (3.0 Gb/s) so you'll need to make sure the drive you do get can run at this I/O speed (many don't). The other option here is to take the big leap to a SSD. Just make sure you get one that has enough space. After you load it up you want to have 1/3 to 1/4 of the drive free more for the smaller SSD's. Again, you do need to be careful here to with the drives I/O speed some SSD's won't play well in a SATA II system.
这个答案有帮助吗?
得分 6
2条评论:
At what point would bottlenecking occur though? With a 2.4 GHz processor would it be able to even make full use of the 10 or 12 GB of ram?
由完成的
Process bottle necking has nothing to do with RAM size.
The issue is the shuttling of inactive processes in RAM to Virtual RAM (V-RAM) which is on the drive to make space for the current running process. So the more RAM the less stress of the drives I/O and the slower I/O access of the drive Vs real RAM.
Reference: What are the differences between virtual memory and physical memory?
由完成的
添加一条评论
max ram on this model is 8GB.. so installing 10 or 12 would not work
这个答案有帮助吗?
得分 1
添加一条评论
I have 16gb and s 500 gb and catalonia and its running fine I c 16gb of ram so info is not
Update (09/12/2021)
Sorry I mean sad 512
这个答案有帮助吗?
得分 0
1条评论:
How is your computer running now with the 16gb ram? You have a 2009 13" mpro?
由完成的
添加一条评论
添加你的答案
guille1203 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 43
总计 25,590
