跳转到主内容
Repair and troubleshooting information for the Barnes & Noble Nook HD+, a 9" screen e-reader and tablet released in November 2012.
touch screen not working
touch screen on nook not working
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Did you already try to hard reset it?
To Hard Reset NOOK HD/NOOK HD+, complete the following:
Confirm the device is powered off.
Hold the Power and Home key simultaneously.
Release the Power and Home key once the NOOK logo appears. A Factory Reset prompt will appear.
To continue, press the Home key.
To exit, press the Power key.
这个答案有帮助吗?
得分 0
2条评论:
I did a factory reset, the keyboard still isn't working. I can't select some of the letters on the keyboard.
完成的
I also have a non-responsive touch screen, although the top menu lights up when touched after the power button is first pushed. Did a reset and factory reset. Still, no touch screen. Would it be more likely a screen problem or a motherboard problem?
完成的
添加一条评论
添加你的答案
john vee 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 9
总计 2,104
