跳转到主内容
加入维修社区 - 创建账户
Nintendo DSi 是 Nintendo DS 产品线的第三款迭代机型,于2008年底在日本市场发布。
The DSi volume button keeps going down.
After I got the dust out of my DSi shoulder buttons by blowing in it the volume kept going down. Does anyone know how to fix this without sending my DSi to Nintendo
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
3个答案
已选择的解决方案
Your "down" volume button is stuck down; check to see if any crumbs or dirt have gotten in there. You might need to replace the SD card slot and volume control assembly.
This part includes the SD card receptor, right and left shoulder button contacts, volume control buttons, and the screen adjustment controls.图片
产品
Nintendo DSi SD Ribbon Cable
$24.99
这个答案有帮助吗?
得分 3
添加一条评论
Take out the SD card from the slot, blow on it, and stick it back in. Then blow in the indention on the volume bar. That worked for me, hope it works for you.
这个答案有帮助吗?
得分 1
添加一条评论
Mine did the same! Have you tried holding down the + button on dsi sound and dragging the volume bar up? If it stays up while you hold that down, then take clear rubber bands and tie them tightly around the dsi on the volume button until they firmly press on the volume button as if a finger was. each time it does it just go to dsi sound and drag the volume bar up with the rubber bands holding down the volume! ^u^ since I've done that for a while, it fixed itself on its own; I guess the dsi's chip gets messed up and thinks that the volume button is pressing on the - button. But there you go, that's how I fixed it! ^u^
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
deleted 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 17
总计 7,904
