跳转到主内容
Aspire 5315 Series features Intel Celeron mobile processor and Mobile Intel GL960 Express Chipset
13 个问题 查看全部
Video card conflict with hidden identical card
I have an old 5315 which i have upgraded to Vista Home Pro and will eventually upgrade to Windows 7. However, it shows a video card conflict. In hidden devices there is another instance of the card conflicting with it. Its a GMA965 chipset, 4 gig dr2, 160 hdisk. Everything else works.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论:
Hi,
Is there any information in BIOS as to what the actual "inbuilt" video display adapter model is? Most laptops have onboard video GPUs not removable cards. Some models, (not yours as far as I can find out) do have two (2) video adapters to allow for swapping between to improve gaming performance. Again they are onboard not removable.
What is Device Manager indicating regarding the status of the Display Adapter?
Can you uninstall both adapters, restart your laptop and then let Windows 'find' the correct adapter?
The Acer support page for your laptop shows this to be the only driver available for the graphics display. VGA Intel VGA Driver 7.14.10.1409 16.2 MB 2008/12/03 and that is for Vista as there is no driver for Win7
完成的
添加一条评论
1个答案
Press the left windows key and the pause/break key at the same time, select device manager and disable one of the video devices.
In the tab that will open for each device is a tab called "details" searching those settings you can find the video device that's causing the problems, click on "Device description", a good start would be checking the "problem code", zeros are a good thing.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
louisturfrey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 170
