跳转到主内容
1.83 GHz Core Duo 处理器 或 1.83, 2, 或 2.16 GHz Core 2 Duo处理器 A1208 (EMC 2104/2110/2114/2124)
201 个问题 查看全部
Repairing LM171W02 screen (make from 2 one)
I've got 2 identical iMac's here (1.83 Ghz Core Duo version), whit 2 defective screens. One has the typical vertical coloured lines (display failure not logicboard), the other one is 1rd black at the right side (the other 2rd is working fine) . Now I thought about fixing one of those 2 (the one whit the 1rd black should be easier), but i'm unable to find any schematics nor any fixing guide.
Does someone has any idea? If necessary I could make some pictures.
/edit: So here is a picture from the one that is 1 third black, or in this case 1/6 black and 1/6 white, this is changing each boot. As I said it's the screen not the logicboard. The division is exactly between the 4th and 5th ribbon from the circuit board of the screen to the screen front.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
@roman78 what do you mean by 1rd black at the right side? Post some images. Let's see what you got there.
完成的
Updated whit photo and more text.
完成的
Sadly enough that looks like another bad LCD
完成的
Yes, I know. But if I know what part causes this I could replace it whit the one from the other display. The display itself (the front) should be OK, it's somewhere on the circuit board of the screen.
Or the other way round: The vertical lines are caused by bad multiplexors (as I read somewhere), it should be possible to replace those, whit a SMD solder iron.
完成的
添加一条评论
1个答案
最有帮助的答案
The most common problem with this series was bad capacitors. Open them up and examine the approximately 24 "cans" for swelling and/or leakage.
UPDATE 4/17/16
Here's how to replace the display: iMac Intel 17" 显示屏更换
这个答案有帮助吗?
得分 4
1条评论:
I think those were the G5, mine is an Intel Core Duo. I all ready opened it. There are only 3 Caps inside, all looking normal. Also I noticed that those caps were all ready replaced, I noticed on the back.
完成的
添加一条评论
添加你的答案
Roman78 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 4
总计 429
