跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
How do I make my phone boot?
my phone was working perfectly fine last night but when i woke up it was switched of, when i turn it on the apple logo disappears when i take my finger of the power button, i tried putting it into DFU and recovery mode but nothing worked i plugged it into itunes to restore or update it and i got error 3194 i checked my host file and all was fine. i dont know what else i can do please help!!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
Hi Ben
Did you try to restore it from another computer. This may help.
Good luck
这个答案有帮助吗?
得分 0
4条评论:
gives me the same error
完成的
Can you try restoring by switching off the phone press the home button and hold connect to your computer and hold the home button until you see the itunes then let it go and try restoring.
完成的
i tried that but i cant get the itunes logo to appear as soon as i remove my finger from the power button the boot logo dissapears and just goes black until i turn it off
完成的
Can you change the battery and the charging port?
完成的
添加一条评论
Hello Ben Knifton,
This HT document will help you to troubleshoot your connection issue.
这个答案有帮助吗?
得分 0
添加一条评论
As a desperate attempt you can search for your phone on cyanogenmod.org. They create custom ROMS for rooted phones (legal), there are several ways to boot a phone, one being into recovery mode.
这个答案有帮助吗?
得分 0
添加一条评论
Hello, I've had similar problems and restoring with Libmobiledevice may help.
Google it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ben Knifton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 131
