跳转到主内容
加入维修社区 - 创建账户
Nissan Altima 是一款由日产制造的中型汽车,可以说它是 1957 年开始的 Nissan Bluebird 系列的延续。
2006 Front headlight assembly
How do you remove the front headlight assembly to replace a burnt out bulb?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
Take the keys out of the ignition and switch the headlights off. Then, open the hood using the primary and auxiliary release latches.
2
Use a socket wrench to remove the two 10mm bolts holding the coolant overflow bottle in place. Pull the bottle out of the engine compartment and set it on the ground (passenger's side bulb replacement only.)
3
Undo the bolt at the top of the air filter box, lift the top open and remove the filter from the engine compartment. Then, undo the fasteners holding the air dam in place and remove it from the filter box (driver's side bulb replacement only.)
4
Pull the entire air box out of the car to access the backside of the headlight assembly.
5
Turn the bulb socket counterclockwise to remove it from the assembly. Then, release the retaining spring, undo the electrical connector and carefully remove the old bulb from the socket.
6
Hold the new bulb by its plastic base and insert it into the socket. Reattach the electrical connector and replace the retaining spring.
7
Switch the headlights on to test the new bulb. If it works, reinstall the air box or coolant bottle and close the hood.
这个答案有帮助吗?
得分 2
1条评论:
Thorough +
由完成的 分享
添加一条评论
How do I know if the head lamp went out from a bad fuse or a burnt light bulb
这个答案有帮助吗?
得分 0
1条评论:
Check all of your fuses... I just had to do this yesterday, it's a little annoying...but saved me a bunch of money!!
由完成的 分享
添加一条评论
添加你的答案
Melvin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 34
总计 27,693
