跳转到主内容
加入维修社区 - 创建账户
Bose QuietComfort 2 主动降噪耳机的维修指南。发布于 2003 年。型号:QC2。
Battery spring is bent
battery spring is bent and does not cover end of battery, and makes clicking noise
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论:
All you need is metal on metal contact. So if you have a broken pen then you can use a pen spring to put in-between the old spring and the battery that is if the pen spring isn't too large. You could also pull the battery spring and make it longer but it will deform it and it still might not work. What ever you do have fun with it.
由完成的
添加一条评论
1个答案
Hi John I got a solution if you know how to take the bent spring out. There is only one way that I know on how to find the right spring I do this a lot. I take the bad spring out of the device and then go to a hardware store and ask where are all the springs are. At my local hardware store they actually have trays full of different size springs and I match the new spring up with the old one. But on how to take the spring out of that device is beyond me. I wish I could help more but I don't know that much about working on good headphones sorry. I am sure someone can come in on my downfall and help you with that .
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John Mueller 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 19
总计 3,795
