跳转到主内容
加入维修社区 - 创建账户
更新版 Apple TV,配备第二代 A5 处理器 / 发布于 2012 年 3 月 7 日
Warning message Apple TV overheating
Hi
My Apple TV 3rd gen had started displaying message:
'warning' 'apple tv is overheating and will shut down , this message will disappear when apple tv is ready' or something very similar. The unit is in a well ventilated area and has never been abused, and is less then 3 years old. Ive updated the software( it barely let me do that before failing) and ive tried resets etc. but it isn't possible to even turn the unit off now , only by unplugging the power lead.
Any help tips or advice would be most appreciated
Regards
Mark
York UK
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
How old is it?
由完成的
Image pleasr
由完成的
添加一条评论
2个答案
Did you try using some can'ed air to blow the dust out from the inside yet?
Also make sure you give it some breathing room, you don't want to cook in a closed cabinet with other hot gear.
这个答案有帮助吗?
得分 0
添加一条评论
It is most likely the on board temp sensor. The only thing I can think of would be to disassemble everything right down to the board and do a solder re flow, by either using a heat gun to bring the board up to temperature so all the solder points re connect or you can also do this in an oven. This method is for repairing cold solder joints on the board, which could be the cause if the machine heated up enough to melt the solder and cause it to loose its contact. Try Google and search for "Solder Reflow"
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mark Hansell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 25
过去 30 天: 41
总计 2,989
