跳转到主内容
加入维修社区 - 创建账户
USB 闪存盘(也称为闪存盘、U 盘或移动存储棒)的维修指南和技术支持。
How do I fix a DEAD flash Drive?
I have a Crucial 32 Folding flash drive. Worked fine on Tuesday night, plugged it in on Wednesday morning and... Nothing. Absolutely nothing! Problem is, it contains ALL my files (of course) which I need (of course). Is there a way to fix it myself (I have a "little bit" of electronics skills) , or should I send it off and jus pay the $$$$ to have it fixed and data recovered? Any ideas, suggestions? HELP?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 11
4条评论
Did you rule out the computer usb ports? If so, you can start with an electronics cleaner and brush in the flashdrive plug.
由完成的
Yes. Tried it in two diff computers. It "thinks" when I plug it in , then nothing. Opened it, no fuses or bad connectors . now what??? Is there a way to directly access the chip? Or can I take the chip out & put it into one that works?
由完成的
i have a dead usb and a I want to repair it. but no , i trying diskpart,mini partition and disk genius but no. but he doesn't want to create a partition for me pls a app he is reparing a usb
由完成的
hi there is t there a way to get access to a dead USB
由完成的
添加一条评论
4个答案
最有帮助的答案
Before you take it apart try downloading easeus data recovery see if you can see your data there
这个答案有帮助吗?
得分 5
4条评论:
Good thought.
由完成的
@pccheese explain your vote on this answer to me.
由完成的
@oldturkey03 I have found no solution in the answer. It would be wiser to "remove as not an answer" than spam, though. My reason for a spam vote is because the recommendation of the software without any actual problem solving.
由完成的
@pccheese actually I think it is very wise to check recovery programs before a physical repair. I'd think spam if there would have been an actual link to it, but there was not. Looks like personal preference to me;-)
由完成的
添加一条评论
A BGA rework professional may be able to swap the memory to a new flashdrive, but without a hot air station you don't have a hope of switching it. Try pressing on the chips while you plug it in. Maybe it will work long enough to get your data. If not I would have to say send it in and pay. :(
这个答案有帮助吗?
得分 1
添加一条评论
use partitionGuru Software
and change the drive letter maybe from E to R
这个答案有帮助吗?
得分 1
添加一条评论
If your Crucial 32GB Folding Flash Drive suddenly isn’t detected, first try basic checks: use different USB ports, another computer, and avoid USB hubs. Check Disk Management (Windows) to see if it appears unassigned. If detected, don’t format—use recovery tools like Recuva or TestDisk.
If it’s completely dead (no detection), it’s likely controller failure—DIY repair is risky and can worsen data loss. In that case, professional recovery is safest. Avoid repeated plugging attempts, as it may damage the memory further.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
deadflash 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 41
总计 18,232
