跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
问题已关闭
Antenna Wire Next to Battery Conection
There is a single wire (black) connection under the battery connection retention plate that is removed during the loudspeaker replacement. That connection "broke" during an attempt to replace the speaker. How can I fix it? Also, purchased a new speaker (loudspeaker) for this phone and first install did not fix it. Still got audio through the headphone jack but not loudspeaker. 2nd attempt to double check is when the "antenna wire" got broken. Any help on either problem appreciated?
Mitch
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Found the repair part and ordered. Did not see a repair procedure posted but confident that I will be able to figure it out. Still scratching my head over the speaker issue if anyone has suggestions?
完成的
添加一条评论
2个答案
已选择的解决方案
Beleive it or not, I replaced the Lightening Port and it repaired both the antenna and the Speaker. This was after putting 3 different speakers in. I am not sure exactly how or why but the phone is fixed.
这个答案有帮助吗?
得分 0
添加一条评论
Hi
Replace the charging port and that should solve the issue.
Good luck
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 105
