跳转到主内容
佳能 EOS Rebel T3i 于 2011 年 3 月发布,可以通过其 SKU (SKU:5169BO32) 来识别。这款相机也被称为 EOS 600D 和 EOS Kiss X5,是一款具有1800万像素的佳能数码单反相机。
SD card slot does not work
My SD card slot does not work anymore and I bought a new SD PCB assembly for it. (http://uscamera.com/cg2-3308.htm) Do you have a guide on how I could replace this? I could probably figure out how to do it myself, but it would make me feel better to have instructions
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Use this guide to remove the main board, which is probably the most delicate part of the operation. The SD card board is on the right side under the main board, and should be accessible once you remove the former. There are 3 connectors on the SD board: One flat to the main board, one wired two pin connector to the power board (top right) and one small flat that goes somewhere on the chassis (bottom left). Once all connectors have been detached, you can undo the 4 screws that hold the SD board, take it out, and fit the replacement.
Take utmost care not to damage the flat cables and the connectors. Some flat connectors have locking tabs that must be flipped up before you can extract the cable. Some large flats such as the one that connects to the sensor board have press fit connectors that pop out vertically (at right angle to the board), these should be carefully lifted out with the tip of a plastic spudger. Putting them back is easy, just line it up correctly and gently push it in place with your fingertips until it "clicks".
Once the replacement board is fitted, just follow the guide in reverse to put everything back together again.
这个答案有帮助吗?
得分 5
1条评论:
Any other suggestions what this error could be caused by? I have replaced the sd card slot and am still getting "no card in camera"
完成的
添加一条评论
If SD card slot is not working then you can remove the dust from slot or you can replace to SD card slot also.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
podraziya 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 18
总计 4,822
