跳转到主内容
加入维修社区 - 创建账户
Farberware 咖啡壶的支持页面。
Coffee pot does not turn off - just replaced the thermostat.
I have an 8-cup Farberware coffee percolator (FCP280) that stopped heating properly (it would not get hot enough and made tea-colored coffee). I replaced the thermostat with a ceramic thermostat for coffee makers that is supposed to turn on at 131 degrees and off at 145 degrees. I tested it with just water and with coffee and it percolated for 15 minutes at which time I unplugged it. Also, I checked the temperature of the coffee and it was 200 degrees.
Any suggestions?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
11条评论
@vineandvalley double check your wiring and make sure it is properly routed. Sounds like your thermostat is at fault here. I'd check the data sheet for the thermostat and see when it cuts on-off and what contacts will have to be connected for that to happen.
完成的
It didn't come with a data sheet, but I will see if I can find one online. Thanks!
完成的
I'm out of my element looking for data sheets. However, this is what I know about the thermostat:
"Ceramic thermostat 145 degree, used in many coffeemakers. Rated 10amp, 250v. Temperature rise off at 145 degrees temperature, temperature fall on at 131 degrees."
Is is possible to install this in the reverse? There is nothing that indicates that one terminal is different from the other.
http://www.goodmans.net/i/4868/ceramic-t...
完成的
Not really because it is a simple switch that opens and close its contacts according to the temp. Of course you can always try to reverse the wiring. The concern here is that it went all the way to 200 degrees....
完成的
That's my understanding of this type of switch, too. I'm perplexed. I bought two thermostats to have a back up and the second one operates the same way.
完成的
显示更多的6条评论
添加一条评论
2个答案
已选择的解决方案
@vineandvalley Kelly, any chance you can post some images of what you got going on with your percolator. Just add those to your original question. Use this guide 在已经存在的问题里加入图片 to add those. I am interested to see where the thermostat sits and how it is mounted. I believe that the thermal side is just getting pushed against the "boiler" case with a spring clip. I was wondering if may be your replacement thermostat does not properly sit against the case for a proper reading. I'd try to use a Farberware replacement thermostat like this and a bit more expensive on here.
这个答案有帮助吗?
得分 1
2条评论:
I will get a picture up, but might take me a few days since I'm headed into the work week. Yes, the thermostat sits against the bottom of the pot. I'll look at the two surfaces. The Farberware replacement is not available on a lot of sites, which is why I went with the Univen part. Thanks for looking up some vendors. I dislike the idea of paying $10+shipping for a part that should cost $2-5, though. :( Pesky percolator.
完成的
I hate it as well. Just thinking if it does not sit snug against the urn it may not read the temp right.....have a great week
完成的
添加一条评论
relay switch inside the maker itself
这个答案有帮助吗?
得分 0
3条评论:
I'm going to check, but I think there is only the thermostat, heating coil, and connecting wires. I'm not sure what you mean by relay switch inside the maker.
完成的
@jebus there is no relay in this percolator.
完成的
Ceramic thermostats like this one described turn off at 145 degrees Celsius - which is 293 Fahrenheit. - Irontender
完成的
添加一条评论
添加你的答案
Kelly 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 2,491
