跳转到主内容
Repair and troubleshooting information for the Suzuki FA50 Moped.
75 个问题 查看全部
need a fuel + oil line diagram for repacling new carb
looking for a diagram for 1984 Suzuki FA50 fuel + oil line connections
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
The line that is closest to the carb flange is a vac line and goes to the topmost nipple on you fuel switch,the line closest to the back of carb goes to the nipple closest to the bottom of the fuel switch.the other two lines go to your fuel tank.the one closest to bottom of tank is ur reserve line while the one above it is your run line. You,ll probably have to install a couple inline filters as the ones in the ends of the lines are very difficult to salvage.
Update (06/23/2016)
As for the oil,you have one line from tank to the pump and a smaller outlet hose over to the rt. side of the crankcase. Hope this helps.
这个答案有帮助吗?
得分 2
添加一条评论
kingwaynejtp I am a little confused by what it is that you are looking for. Download the service manual from the bottom of this page and see if that will help you with your task,
这个答案有帮助吗?
得分 1
添加一条评论
Ran out of gas. Oil is coming out the tail pipe been sitting. Will oil run into carb????
这个答案有帮助吗?
得分 0
1条评论:
No.oil will not go into the carb.
完成的
添加一条评论
添加你的答案
kingwaynejtp 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 33
总计 2,172
