need a fuel + oil line diagram for repacling new carb
looking for a diagram for 1984 Suzuki FA50 fuel + oil line connections
The line that is closest to the carb flange is a vac line and goes to the topmost nipple on you fuel switch,the line closest to the back of carb goes to the nipple closest to the bottom of the fuel switch.the other two lines go to your fuel tank.the one closest to bottom of tank is ur reserve line while the one above it is your run line. You,ll probably have to install a couple inline filters as the ones in the ends of the lines are very difficult to salvage.
As for the oil,you have one line from tank to the pump and a smaller outlet hose over to the rt. side of the crankcase. Hope this helps.
这个答案有帮助吗?
kingwaynejtp I am a little confused by what it is that you are looking for. Download the service manual from the bottom of this page and see if that will help you with your task,
这个答案有帮助吗?
Ran out of gas. Oil is coming out the tail pipe been sitting. Will oil run into carb????
这个答案有帮助吗?
No.oil will not go into the carb.
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 34
总计 2,173
