跳转到主内容
第一代苹果iPad 配备有WiFi 提供16.32或64GB 型号为A1219 维修是直接的不需要任何加热。
130 个问题 查看全部
How continue to use an ipad 1 that becomes to be old?
Hi !
Do you have any advise to improve the use of an ipad 1? As this ipad is a bit old, it starts to have some bugs and to work slowly.
I was thinking to put an other OS like Linux? But not sure that will be better or easy. What do you think about it? Do you have any other advise?
Cheers,
Indhy
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
I really wish I had a good answer for you. I didn't buy an Apple watch because I knew the next ones would probably have a camera. I ending put giving mine to my granddaughter. Planned corporate obsolescence. No new app support.
这个答案有帮助吗?
得分 3
添加一条评论
最有帮助的答案
indhy31 you may just run into trouble with a different OS since it most likely will not support the hardware. Delete all unnecessary apps and files. It is still a great tablet and you can continue to use it for the simpler things. Remember that as consumers demand faster, smaller, (and perceived)better devices, companies will have to drop supporting legacy devices. Ask yourself the question of what you need this iPad for and if the iPad still meets those needs. If it does not, or if you have higher expectations, purchase a faster, smaller, (and perceived)better device. Donate yours to people that may still appreciate it.
这个答案有帮助吗?
得分 5
添加一条评论
添加你的答案
indhy31 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 6
总计 1,170
